Determin if connection was SSL
matthewb99
Does anyone know of a method for a web application behind a CSS11506 to determine if the connection from the client to the CSS was SSL without using backend SSL?
Is there anyway of inserting a HTTP header or anything like that?
Thanks.
owillins
Level 6
Level 6
I am not sure of a way to do it. You could check up some documents on the CSS 11500 and see if it is mentioned.
http://www.cisco.com/pcgi-bin/Support/browse/psp_view.pl?p=Hardware:CSS_11500_Series_Content_Services_Switches
