Difference between CallType Internal and Transfer In
rtencza
Can someone give me a detailed explanation of the difference between a call being labeled as a Transfer In vs Internal under contactType in ContactCallDetail? In the schema 3 is Internal and 5 is Transfer In. The explanation for Internal is as follows "Call transferred or conferenced between agents, or a call made within the system." However there is not a definition for Transfer In. The definition for Internal sounds just like what a Transfer In would be.
0 Replies 0
