Error al inciar interface Web Cisco Prime 3.0
jorge.barrera
TCQ-PRIME/admin# ncs status
Exception in thread "main" java.util.NoSuchElementException
at java.util.Scanner.throwFor(Unknown Source)
at java.util.Scanner.next(Unknown Source)
at com.cisco.common.ha.config.HighAvailabilityConfig.parseXmlFile(HighAvailabilityConfig.java:232)
at com.cisco.common.ha.config.HighAvailabilityConfig.parseXmlFile(HighAvailabilityConfig.java:214)
at com.cisco.common.ha.config.HighAvailabilityConfig.<init>(HighAvailabilityConfig.java:194)
at com.cisco.common.ha.config.HighAvailabilityConfig.getInstance(HighAvailabilityConfig.java:203)
at com.cisco.packaging.HMAdmin.initHealthMonitorApi(HMAdmin.java:409)
at com.cisco.packaging.HMAdmin.hmServerStatus(HMAdmin.java:302)
at com.cisco.packaging.HMAdmin.status(HMAdmin.java:172)
at com.cisco.packaging.WCSAdmin.status(WCSAdmin.java:1022)
at com.cisco.packaging.WCSAdmin.status(WCSAdmin.java:995)
at com.cisco.packaging.WCSAdmin.runMain(WCSAdmin.java:310)
at com.cisco.packaging.WCSAdmin.main(WCSAdmin.java:1437)
CNS Gateway with port 11011 is down
CNS Gateway SSL with port 11012 is down
CNS Gateway with port 11013 is down
CNS Gateway SSL with port 11014 is down
Plug and Play Gateway Broker with port 61617 is down
Plug and Play Gateway config, image and resource are down on https
Plug and Play Gateway is stopped.
SAM Daemon is stopped.
DA Daemon is stopped.
TCQ-PRIME/admin#
TCQ-PRIME/admin#
TCQ-PRIME/admin#
0 Replies 0
