FT failover not working
12pratham
We have 2 ACEs configured as Active/Standby.  FT vlan is configured directly using a crossover cable , not using a switch for the FT vlan
ACE is setup in routed mode ,vlan 29 is client vlan and 28 is server vlan ,both are being trunked on ACE-- trunk  3750 switch.
When I shutdown the port on 3750 for the primary ACE , data connectivity wise ,primary ACE is down ,but the secondary is not taking over ,and also
when I do sh ft group status  on the secondary ACE,I see the status of  STANDBY_HOT and the peer state: ACTIVE.
Not sure why its not failing over . when I disable the port on switch.
below is my ft config
Primary
ft interface vlan 1003
  ip address 1.1.1.1 255.255.255.252
  peer ip address 1.1.1.2 255.255.255.252
  no shutdown
ft peer 1
  heartbeat interval 300
  heartbeat count 10
  ft-interface vlan 1003
ft group 10
  peer 1
  no preempt
  priority 255
  peer priority 250
  associate-context Admin
  inservice
ft track interface PCI
  track-interface vlan 29
  peer track-interface vlan 29
  priority 20
ft group 11
  peer 1
  no preempt
  priority 255
  peer priority 250
  associate-context EPS-PCI
  inservice
Secondary
  peer ip address 1.1.1.1 255.255.255.252
  no shutdown
ft peer 1
  heartbeat count 10
ft group 10
  peer 1
  no preempt
  priority 250
  peer priority 255
  inservice
  peer priority 20
ft group 11
  peer 1
  no preempt
  priority 250
  peer priority 255
  inservice
5 Replies 5
gaursin2
Level 7
Level 7
hi
two issues which I see in your config are:
a. less priority in "ft track interface PCI"----configure a priority which will be reduced from current priority so that active will have less priority then that of standby (take 100 for e.g, so if vlan 29 go down, active priority become 255-100=155)
b. "no preempt" in FT groups----so even when priority is reduce this command will hold standby preempting the active (same like HSRP).
Gaurav
Thanks for the reply ,you mean I need to change my ft track interface PCI ,priority from 20 to 100 ,and also enable the preemt command on the ft groups
On cisco docs ,its says ,when we configure FT track interface ,the ,i haven't set any peer priority so the value is 0
so (255-20 ==245)
for peer( 250-0 ==250)  stanby has high priority so it should become active.
Correct me if I am wrong
Jorge Bejarano
Level 10
Level 10
Some things here, why do not try to change the priorities of all your group to be
priority 250 / peer priority 255? There are some of them which have different priorities or even you can have the same priority and if you have preempt disabled then it will take the higher ip address configured as the prefered active.
Additionally, I wonder if you can try:
  peer track-interface vlan 1003
  priority 50
  peer priority 5
Hope this helps!!!
Jorge
We configured the FT
configuration of the ft interface and group on primary ace
  no shutdown
ft peer 1
  heartbeat count 10
ft group 10
  peer 1
  priority 225
  peer priority 200
  inservice
  priority 100
  peer priority 50
ft group 11
  peer 1
  priority 225
  peer priority 200
  associate-context EPS-PROD
  inservice
when the switch port is shutdown  for the primary ACE,secondary took over for the admin context .,and the application was not reachable  as the context dint switch over ,let me know if we need to change any value
out of ft group of secondary
ace2/Admin# sh ft group status
FT Group                     : 10
Configured Status            : in-service
Maintenance mode             : MAINT_MODE_OFF
My State                     : FSM_FT_STATE_ACTIVE
Peer State                   : FSM_FT_STATE_STANDBY_HOT
Peer Id                      : 1
No. of Contexts              : 1
Running cfg sync status      : Running configuration sync has completed
Startup cfg sync status      : Startup configuration sync has completed
FT Group                     : 11
My State                     : FSM_FT_STATE_STANDBY_HOT
Peer State                   : FSM_FT_STATE_ACTIVE
Peer Id                      : 1
No. of Contexts              : 1
ace2/Admin#
NOTE: Configuration mode has been disabled on all sessions
Sorry but i didn't understand you saying "application was not reachable  as the context dint switch over", which context are we talking here "EPS-PCI", then if you use show ft track summary command it will show you which context this tracking is mapped with. in your case its only Admin to which it is mapped.
So please create a similiar track (only ft track and no other ft configuration) inside the desire context also...
