FTP 3 way handshake not completing for just a single host!
DAZN_Network
I have a problem with our ACE load balancers. We run a public FTP server farm which is load balanced using the ACEs. I have come across a problem which is very peculiar and is only affecting a single host, one of our offices in Poland.
Basically, the servers support Passive and Active FTP. We have clients that access the FTP service every other second so we know the existing configuration works just fine. However, our office in Poland, which sits behind a public NAT on a firewall, is unable to access our FTP service.
I have taken good and bad traces and noticed that the final TCP ACK from the client that should complete the hand shake, never makes it past the ace. The ACE show me the connection in SYNSEEN and SYNACK but never make it to the ESTABLISHED state.
PERSLOACE1/FRONT_END# show conn address x.x.x.x netmask 255.255.255.255 detail | i :21
1770432    1  in  TCP   201  x.x.x.x:30951   87.83.27.52:21        SYNSEEN
934881     1  out TCP   200  y.y.y.y:21        x.x.x.x:30951          SYNACK
The ACE is carved into contexts and the same is seen on all of them.
The office in Poland can access other FTP sites on the Internet (i.e Mozilla) so we know the problem is not localised there. Also, various customers access our FTP service so we know there is nothing wring there either.
I have spent hours trying to find related issues on the Internet but haven't found any!
In looking at my traces, the only difference I can see is that healthy packets have the DF bit set on the IP header, whereas packets from Poland do not. Could it be related? Something to do with fragmentation and/or normalisation?
When issuing the show serverfarm command, I can see failure counters incrementing but I am unable to make a connection with a cause. The 'show np' outputs are not very clear.
PERSLOACE1/FRONT_END# show serverfarm Download_FTP detail
serverfarm     : Download_FTP, type: HOST
total rservers : 3
active rservers: 3
description    : -
state          : ACTIVE
predictor      : ROUNDROBIN
failaction     : -
back-inservice    : 0
partial-threshold : 0
num times failover       : 0
num times back inservice : 0
total conn-dropcount : 0
Probe(s) :
    FTP_DL,  type = FTP
                                                ----------connections-----------
       real                  weight state        current    total      failures
   rserver: FT Server 1
       x.x.x.x:0         8      OPERATIONAL  13         83477      15
         description          : -
         max-conns            : -         , out-of-rotation count : -
         min-conns            : -
         conn-rate-limit      : -         , out-of-rotation count : -
         bandwidth-rate-limit : -         , out-of-rotation count : -
         retcode out-of-rotation count : -
         load value           : 0
   rserver: FTP Server 2
       x.x.x.x:0         8      OPERATIONAL  17         1269       10
         description          : -
         min-conns            : -
         load value           : 0
   rserver: FTP Server 3
       x.x.x.x:0         8      OPERATIONAL  21         2378       23
         description          : -
         min-conns            : -
         load value           : 0
Here is the config below:
probe ftp FTP_DL
  description FTP Probe
  interval 60
  passdetect interval 60
  expect status 220 220
rserver host FTP Server 1
  ip address x.x.x.x
  inservice
rserver host FTP Server 2
  ip address x.x.x.x
  inservice
rserver host FTP Server 3
  ip address x.x.x.x
  inservice
serverfarm host Download_FTP
  probe FTP_DL
  rserver FTP Server 1
    inservice
  rserver FTP Server 2
    inservice
  rserver FTP Server 3
    inservice
sticky ip-netmask 255.255.255.255 address both FTP_DL
  timeout 20
  replicate sticky
class-map match-any FTP_DL
  2 match virtual-address 87.83.27.52 tcp eq ftp
  3 match virtual-address 87.83.27.52 tcp eq ftp-data
  4 match virtual-address 87.83.27.52 any
policy-map type loadbalance first-match FTP_DL
  class class-default
    sticky-serverfarm FTP_DL
policy-map type loadbalance first-match FTP_DL_Active
  class class-default
policy-map multi-match FTP_Download
  class FTP_DL
    loadbalance vip inservice
    loadbalance policy FTP_DL
  class FTP_DL_Active
    loadbalance policy FTP_DL_Active
    inspect ftp
interface vlan 201
  description ACE-FW Vlan for FWLB
  ip address "gw ip' x.x.x.x /y'
  alias x.x.x.x /y
  peer ip address x.x.x.x /y
  mac-sticky enable
  access-group input ANY
  access-group output ANY
   service-policy input FTP_Download
What is happening??!  Please help. Happy to provide more show outputs
Many thanks
5 Replies 5
Kanwaljeet Singh
So it seems that client ACK is not making it back to the ACE or the servers. Have you got the pcaps which show that ACK packet came to the ACE and ACE didn't send it back to the server?
If it is sending the SYN i am not sure why it would have a problem with ACK.
Normalization could have caused a problem if ACK was seen ACE without seeing the corresponding SYN so doesn't look like a Normalization issue here.
Can you take a simultaneous front end and back end pcap which establishes the fact that ACK packet was given to ACE but ACE didn't send it back to server?
Kanwal
Hi Kanwal
Thanks for your input. Yes, I have taken traces in both the incoming vlan (inbound) and outgoing vlan (inbound) and I can see the client ack being lost in the ACE somewhere. The packet needs to switch contexts to make it from client (perimeter side) to the server (back end side). COuld this be related?
As you can see from the show serverfarm output, the failures count is incrementing so I am convinced the ACE is dropping the ACK for some unknown reason.
Simon
Hi Simon,
Inter -context traffic could be a problem but it is working for every other host and not just this one(i assume you have proper routing in place for inter-context communication) , correct?
I would suggest opening a TAC case for detailed investigation.
Kanwal
Hi Kanwal,
Yes, routing is correct as the initial SYN and SYN-ACK packets make it correcty to the end hosts.
I am waiting for our support contracts to be mapped onto our account so I can't open a TAC case yet, but if there are any more suggestions, especially with show command outputs, they'd be welcome.
Simon
Hi Simon,
The Connections Failures counter for a real server in a server farm may increment for one of the following reasons:
  • SYN timeout (the three-way handshake fails to complete)
  • RST received (a client sends an RST to the server)
  • Internal exception (internal software issue)
Now, strange thing is this is happening for only for one HOST and you have pcap which shows that client ACK was sent to the ACE.
Can you send me the front end as well as backend pcap which shows that SYN from ACE made it to the backend but client ACK didn't?
Is it possible for you to take a ACE Backplane capture during the time of issue and send it to me for analysis?
Do grab two instances of show tech with a time difference of 5 minutes during the time of issue from the affected context.
Do indicate what are the IP' i need to look at  like client IP, VIP etc.
I will have a look and see what comes out. I have a feeling that this might need to go to development and without TAC case that won't be possible. If we do see ACK making it to the ACE and lost in ACE then we will need to have all that information (requested above) , open a TAC case and go to development for analysis.
But let's see.
You can also try and take capture on ACE itself. One for working client and one for non working client would be very helpful.
Kanwal
