ftp data transfering drops when failover from active to backup
gaojianwen
Hi All,
I did a failover testing with 2 CSS11503 and found a ftp problem.
I ftp one file from the server which behind 2 CSS, I tried to force failover happen by shutdown external interface. The ftp transfering was also terminated.
How can I keep file still transfering when the active css failover to the backup one? Thanks.
!************************** SERVICE **************************
service ftp1
ip address x.x.x.186
port 21
keepalive port 21
keepalive type tcp
redundant-index 7
keepalive frequency 2
keepalive maxfailure 2
keepalive retryperiod 2
active
service ftp2
ip address x.x.x.189
port 21
keepalive port 21
keepalive type tcp
redundant-index 8
active
!*************************** OWNER ***************************
owner owner1
content content2
protocol tcp
port 21
add service ftp1
vip address 10.10.1.5
redundant-index 2
add service ftp2
application ftp-control
active
!*************************** GROUP ***************************
group ftpservers
add service ftp1
add service ftp2
redundant-index 11
active
Gilles Dufour
I did not try it, but I believe it should work.
What version do you run ?
Gilles.
Hi Gilles,
The version is 8.10. It would be great if you can test it.
Jianwen.
could you try to force failover by rebooting the CSS.
Just want to see if we get the same result.
I'm going on vacation tonight so I won't be able to test until july 15th.
You can open a service request with the TAC and they can test if for you.
Or you can wait till july 15th and I'll do it for you [just repost a question on that day so I do not forget]
Gilles.
Gilles,
The failover was successful while rebooting the active CSS. The transfering didn't drop.
Thanks.
Jianwen
