FTP through ACE
Dear Mister
I need to pass FTP  through ACE, but the is not functioning.
The FTP is not functioning using  VIP. It is a connection toward a NAT ip address. I have the next configuration:
class-map match-all NAT2020-PRUEBA
  2 match source-address 10.40.20.20 255.255.255.255
interface vlan 401
  description "Conexion a Servidores Reales CERT"
  ip address 10.84.255.10 255.255.255.248
no shutdown
interface vlan 450
  description "Conexion a FWSM-CERT"
  ip address 10.40.150.3 255.255.255.128
service-policy input NATTEST
no shut
I need to do the NAT using the real IP 10.40.150.10.
policy-map multi-match NATTEST
  class NAT2020-PRUEBA
nat static 10.40.150.10 netmask 255.255.255.255
In this scenary, the NAT is not functioning.
I tried to user the next:
switch/cert(config-pmap-c)# nat static 10.40.150.10 netmask 255.255.255.255 21 vlan 401
But send the next message.
Error: Invalid real port configured for NAT static
How I could fix this problem????
Some inspect???
Best Regards
7 Replies 7
mwinnett
Level 7
Level 7
Config is as follows. You need the 2 class-maops, one for vip and one for the servers. If not, then the PASV statement will not get the server IP translated
Matthew
rserver host 810
  ip address 1.8.1.10
  inservice
rserver host 811
  ip address 1.8.1.11
  inservice
serverfarm host 8xx  rserver 810
    inservice
  rserver 811
    inservice
class-map match-all ftp-source
  2 match source-address 1.9.1.0 255.255.255.0
class-map match-all vip-ftp
  10 match virtual-address 1.9.1.209 tcp eq ftp
policy-map type loadbalance first-match round-robin-8xx
  class class-default
    serverfarm 8xx
policy-map multi-match lb-vip
  class vip-ftp
    loadbalance vip inservice
    loadbalance policy round-robin-8xx
    loadbalance vip icmp-reply
    inspect ftp
  class ftp-source
    nat dynamic 1 vlan 468
interface vlan 468
  description Server vlan
  ip address 1.8.1.201 255.255.255.0
  nat-pool 1 1.8.1.208 1.8.1.208 netmask 255.255.255.255 pat
  no shutdown
interface vlan 469
  description Client vlan
  ip address 1.9.1.201 255.255.255.0
  service-policy input lb-vip
  no shutdown
ip route 0.0.0.0 0.0.0.0 1.9.1.254
Thank mister
But at this point, a have static NAT. I put before just a one FTP Rserver, but really, are two.
In essence, I need two STATIC nat. I am not using PAT.
How could I do this?
Best Regards
Rodrigo, sorry I don't follow what you are trying to do. In terms of NAT, you have destination nat as the client connects to the VIP address. I assume that you have a problem with source nat - is that correct. Are you sayin that you have 2 clients and you want to static nat each one to different values ? Matthew
Thanks Mattew
My problem is with the FTP, using these NATs.
The reals IPs must to be see from the outside in this way:
10.40.20.20 ( Real Server) --> 10.40.150.20 (nop vip)
10.40.21.20 ( Real Server) --> 10.40.150.21 (nop vip)
In this scenary, the clients need to get and put files in this Servers FTP (10.40.150.20 and 21), without load balancing.
In this scenary, I connect to then servers, but when I try to do a "ls", or "dir" o get some file, is not functioning.
Best Regards
So you want the clients to access rserver 10.40.20.20,via ftp to 10.40.150.20 and rserver 10.40.21.20 via ftp to 10.40.150.21 ? The rservers expect to see the real client source address ? Matthew
Mattew
About that :
Yes, that is correct.
Maybe, I am not fully understan the functioning of FTP. Customer in appearance is making Passive FTP.
This should do what I think you want to do. THis also does source-nat. If you dont-t ewant this, then delect the class-maps ftp-810 & ftp-811 and the nat statements from vlan 468. Matthew
rserver host 810
  ip address 1.8.1.10
  inservice
rserver host 811
  ip address 1.8.1.11
  inservice
serverfarm host sf-810
  rserver 810
    inservice
serverfarm host sf-811
  rserver 811
    inservice
class-map match-all ftp-810
  2 match virtual-address 1.9.1.209 tcp any
class-map match-all ftp-811
  2 match virtual-address 1.9.1.208 tcp any
class-map match-all vip-ftp-10
class-map match-all vip-ftp-11
  10 match virtual-address 1.9.1.208 tcp eq ftp
policy-map type loadbalance first-match pm-ftp-10
  class class-default
    serverfarm sf-810
policy-map type loadbalance first-match pm-ftp-11
  class class-default
    serverfarm sf-811
policy-map multi-match lb-vip-10
  class vip-ftp-10
    loadbalance policy pm-ftp-10
    inspect ftp
  class ftp-810
    nat dynamic 9 vlan 468
policy-map multi-match lb-vip-11
  class vip-ftp-11
    loadbalance policy pm-ftp-11
    inspect ftp
  class ftp-811
    nat dynamic 8 vlan 468
interface vlan 468
  nat-pool 9 1.8.1.209 1.8.1.209 netmask 255.255.255.255 pat
  nat-pool 8 1.8.1.208 1.8.1.208 netmask 255.255.255.255 pat
  service-policy input remote-access
interface vlan 469
  service-policy input lb-vip-10
  service-policy input lb-vip-11
