Getting stuck in the first place (ACE)
normbeef
Hi ,
I have a quick question :
we have an ACE loadbalancer that is using a least load predictor based on CPU values of 2 rservers :
We only ever have 4 source addresses that connect inbound to the VIP.
We are seeing that the sticky database keeps sticking 3 entries to one of the servers and 1 on the other,  so the Load balancer is struggling to keep the load even..  (after they are stuck)
My question is    whats is the decision based on to stick the initial connections coming inbound ???     I assume that it uses the least loaded predictor ??
sivaksiv
Thats correct, the initial decision would be based on predictor leastconns.
Regards,Siva
hi sivaksiv,
Thanks for the reply...
I wonder if you can help on the following output....   I see that there are actually 5 sticky sessions (but only 4 possible IP source addresses)   the ACE from time to time ages one of these out  but only to box  v04  ????
you can see below that no new connections are being sent to  sticky entry -  168105287
sticky group : xxxxxx.xxxxxxx-stickygroup
type         : IP
timeout      : 30            timeout-activeconns : TRUE
  sticky-entry          rserver-instance                 time-to-expire flags
  168165518             appv03:0                1777           -
sticky group : xxxxxxxxx-stickygroup
type         : IP
  168165522            appv03:0                1795           -
sticky group : xxxxxxxxxx-stickygroup
type         : IP
  168105287             appv04:0                1284           -
sticky group : xxxxxxxxxxx-stickygroup
type         : IP
  168165523             appv03:0                1752           -
type         : IP
  168165517            appv04:0                1795           -
Cesar Roque
Level 4
Level 4
Did you try using roundrobin?  that probably should give you a more fair loadbalance
Cesar R
ANS Team
--------------------- Cesar R ANS Team
