Showing results forĀ
Search instead forĀ
Did you mean:Ā
GLC-T doesn't work in Nexus 9372PX
verny.alfaro
We have a Cisco Nexus 9372PX unit, and  we try to insert 8 GLC-T without any success. The interfaces appear as: "is down (Link not connected)".
We get connectivity using two old SFPs of the same model, the only difference that I see is:
Nexus# sh int e1/1 transceiver
Ethernet1/1
    transceiver is present
    type is 1000base-T
    name is CISCO-METHODE
    part number is SP7041-R
    revision is
    serial number is MTC1911015W
    nominal bitrate is 1300 MBit/sec
    Link length supported for copper is 100 m
    cisco id is --
    cisco extended id number is 4
Nexus#
Nexus#
Nexus# sh int e1/3 transceiver
Ethernet1/3
    type is 1000base-T
    part number is SP7041_Rev_F
    revision is F
    serial number is MTC134706RS
    cisco id is --
Nexus#
The first port is the one with the working SFP.
has someone experience a situation like this ?.. any help is very appreaciate.
Greetings
Verny
7 Replies 7
Philip D'Ath
Just for the hell of it, can you try hard coding the speed to 1000.
Thanks for your answer Philip, but already did that test, I put the port speed in 1000 without any success.
I'm thinking you need to either try a newer version of Nexus software, or try RMA'ing one of the SFP's in case you have a dud batch.
Thanks Philip:
The actual NXOS version is: version 6.1(2)I3(3a), and I will try to update it.
The reseller give me another SFP's as result of the  RMA requests, but it doesn`t work.
Greetings ...
Hello
The switch was update from 6.1(2)I3(3a) to 7.0(3)I2(2b) without any positive change in the sfps operation.
The retailer open a case in cisco tac, no news or solution yet.
Verny
Verny did you ever find a solution to this?  Our 9372px is rejecting our new GLC-T's as well and we're on 6.1(2)I3(5)
I noticed the functional GLC-T's I have already plugged into it are running version '04' and the ones we just bought are '03'.
In the attached picture the top one is the new GLC-T we bought (notice it's v03)
Bottom one is the GLC-T that was already in the nexus (notice it's v04)
Peter Koltl
Level 7
Level 7
Once I found on a Cat6800 that SFP replacement causes connectivity loss until all the config is removed from the interface then re-added.
