GSS HTTP-Head
durhamcs
Community Member
I am trying to create a keepalive using HTTP-Head
port 443
path = /status.jsp
Can the GSS support the jsp files as a keepalive?
If web server using siteminder for authentication will the GSS be able to do an HTTP-Head test? If not is there a work around?
your problem is that HTTP keepalive only sends HTTP keeplalives. It would not send an SSL handshake and encrypt the request in HTTPS.
Syed iftekhar Ahmed
