Help in setting two ACE appliances in redundancy
ronnel.maranan
Can you please provide a sample configuration on setting up two ACE appliances for redundancy. Also, if you have two redundant ACEs, does the config is copied from the active to the standby or do i have to configure the standby separately?
From the following link
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA1_7_/command/reference/if.html#wp1068700
"ACE automatically includes the FT VLAN in the VLAN trunk link"
It means FT ports are put by default in trunk mode. Could you change the ports on the switches to trunk port and see if it works.
Syed
6 Replies 6
Following link will give you details about ACE redundancy
http://preview.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA3_1_0/configuration/admin/guide/redundcy.html
Config is copied from Active to Standby automatically.You just need to configure FT related config (ft group, ft peer, ft vlan) on the Standby ACE.
Syed Iftekhar Ahmed
not sure why but the link doesnt work for me... to give you an idea i copied the config on my two aces... can you please advise what is wrong with these configs... when i view the status of the the fault tolerant all the heartbeats being sent are missed.
hostname FP_ACE_PlanB_1
interface gigabitEthernet 1/1
switchport trunk allowed vlan 2
no shutdown
interface gigabitEthernet 1/2
shutdown
interface gigabitEthernet 1/3
shutdown
interface gigabitEthernet 1/4
description ACE_Heartbeat
ft-port vlan 320
no shutdown
access-list ALL line 8 extended permit ip any any
class-map type management match-any remote_access
201 match protocol icmp any
202 match protocol telnet any
203 match protocol ssh any
204 match protocol https any
205 match protocol snmp any
policy-map type management first-match remote_mgmt_allow_policy
class remote_access
permit
interface vlan 2
ip address 10.146.2.22 255.255.255.0
alias 10.146.2.21 255.255.255.0
peer ip address 10.146.2.23 255.255.255.0
access-group input ALL
service-policy input remote_mgmt_allow_policy
no shutdown
ft interface vlan 320
ip address 10.146.1.233 255.255.255.252
peer ip address 10.146.1.234 255.255.255.252
no shutdown
ft peer 1
heartbeat interval 200
heartbeat count 20
ft-interface vlan 320
query-interface vlan 2
ft group 1
peer 1
priority 200
peer priority 50
associate-context Admin
inservice
ip route 0.0.0.0 0.0.0.0 10.146.2.1
hostname FP_ACE_Prodn_1
no shutdown
shutdown
shutdown
ft-port vlan 320
no shutdown
2 match protocol xml-https any
4 match protocol icmp any
5 match protocol telnet any
6 match protocol ssh any
7 match protocol http any
8 match protocol https any
9 match protocol snmp any
class remote_access
permit
interface vlan 2
peer ip address 10.146.2.22 255.255.255.0
no shutdown
peer ip address 10.146.1.233 255.255.255.252
no shutdown
ft peer 1
heartbeat count 20
ft group 1
peer 1
priority 50
peer priority 200
inservice
How are the two ACE appliances connected?
Are they using an intermediate switch or a cross cable?
Syed
the ft-port for both ACE are connected using an intermediate switch which are configured as an access port and with access to vlan 320
Ronnel
Syed
you have to make the ft vlan the native vlan in the trunk in order to work.
switchport trunk native vlan "your ft vlan"
