how can I configure two cross-over cable for Redundancy css 11151
qingfeng-hu
hi,all
We have two css11151 connect to PIX(fail-over) ,and we use two cross-over cable between the css, how can I configure it?
1.two separate Circuit vlan ?
2.float IP?
Thanks and with regards.
Gilles Dufour
sorry but I'm not sure what you want to configure ?
If you want to configure redundancy, first tell us what type of redundancy
-box-to-box ?
- vip redundancy ?
- interface redundancy ?
The first type requires a special link between the 2 CSS. But only one.
It will not work if you put 2 links.
The last 2 do not require a back-to-back connection between the CSS.
So, please tell us what is the current design and what is it you're trying achieve.
Gilles.
Gilles Dufour
-box-to-box ?
- vip redundancy ?
Gilles.
