How can I TFTP a running config over to an offline CSS11503
Damon Williams
To save time, I was wondering how can I upload a running configuration via TFTP to flash on a Cisco CSS11503. The CSS11503 is offline at my Data Center.
I want to manually configure a private on it and configure a static IP on my laptop so I can TFTP the running configuration. However since it's my first time doing this on a CSS, I realize the steps is sort of different than a switch or router.
Any suggestions?
Thanks in advance,
Damon W.
CCNA, CCNP, CCNA Voice
Kanwaljeet Singh
Hi Damon,
To copy files from a TFTP server to the script directory or overwrite the startup configuration on the CSS, use the copy tftp command.Then from startup you can copy to running-config.
copy tftp ip_or_host filename [script script_file|startup-config]
Kanwal
Note: Please mark answers if  they are helpful.
Thanks Kanwal,
Now how the next step for me is where to configure an IP address on the CSS. Do I configure the management interface to do TFTP the running config over or do I configure one of the 4 interfaces on the CSS? Which is preferred in this case?
Thanks again,
Damon
Hi Damon,
You can use management interface to do the same. Pasting link for your reference.
http://www.cisco.com/c/en/us/td/docs/app_ntwk_services/data_center_app_services/css11500series/v8-20_v8-10/configuration/quick/guide/getstart/Setup.html#wp1160936
Kanwal
