How Do I configure between Cisco ACE Modules for fail-over in a single 6509?
Seok-Bin Lim
Hello, Sir/Madam,
I have seen a good document for fail-over redundancy of ACE modules.
the url is http://www.cisco.com/en/US/partner/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA3_1_0/configuration/admin/guide/redundcy.html
Now, I know that how Stateful failover is supported across two Cisco Catalyst 6500 Series chassis.
But I do not know how Stateful failover is supported within a Cisco Catalyst 6500 Series chassis.
May I have your suggestions for this question? (configurations)
I guess I can configure the same way that mentioned above url in another ACE appliance even though those are within a single Chassis.
Am I right?
Thanks a lot in advanced.
Lim
ddastoli
Hi Seok-Bin,
HA is supported also within the same Cat6k.
As you correctly said, the configuration is exactly the same, so feel free to follow the one from the URL you mentioned.
Cheers,
Domenico.
ddastoli
Hi Seok-Bin,
Cheers,
Domenico.
Thanks a lot,
I feel free now,
