How do I delete a preposition configuration in CLI
            I have recently upgrade the CM from aWAE612 runn 4.3.3 to vWAAS CM running 5.1.1, Now I did not delete the Preposition configuration I had running before i switched over to the new box. So how in CLI can the unwanted preposition be deleted tried;
  no accelerator cifs preposition 6334213
got the following output>.config: spawnp: verify binary file: /ruby/bin/echo: No such file or directory
Error spawning user process '/ruby/bin/echo': No such file or directory
So how can I delete the unwanted preposition?
Sorry should have looked in the forum more closely
found the correct commad>.
accelerator cifs preposition remove 6334213
