¿how do I match VIP and specific URL on a class-map?
rogelioalvez
Hello team: I would like to loadbalance based on two simultaneous conditions
     Condition 1. specific destination VIP and TCP port
     Condition 2. specific URL content within the HTTP request
Something like: if (destination IP == 10.1.1.1) and (destination port==80) and (URL contains "intranet")
I found this not possible:
     If I select a L4 class-map then I can fulfill Condition1 but  I can not match based on URLs
     If I select a L7 class-map then I can fulfill Condition2 but I can not math based on destination VIP
¿ Is there a way to implement the concept?
Your hints will be greatly appreciated.
Best regards
Rogelio Alvez
Argentina
3 Accepted Solutions
Hi Rogelio,
Then you want to match the destination x.x.x.x under port 80, then hit a virtual address hearing on port 80 and match a url like /intranet, correct?
Basically, you may match the vip in question on port 80 and then on L7 you may configure a class-map which can match the destination and the url.
Jorge
sesoerensen
Rogelio Alvez,
Here's one way:
*/ VIP class-map
class-map match-any [name]
2 match virtual 10.1.1.1 tcp eq 80
*/ URL
class-map type http loadbalance match-any [name]
2 match http url /intranet.* (matches intranet and everything else after that)
or
2 match http url .*intranet.* (matches everything before and after "intranet" if it is not contained in a directory of its own.
*/ Policy map
policy-map type loadbalance http first-match [name]
class [name] (whatever you named the class-map]
  serverfarm or sticky-serverfarm [name] (intranet serverfarm)
  action [if any action lists apply]
class class-default
apply to a multi-match policy map, and attach it to an interface.
You might want to ensure that persistence-rebalance (with or without strict) and case-insensitive is applied using a parameter-map as well.
Cheers Mate.
Sincerely,
Søren Elleby Sørensen
Hola Rogelio,
Ese es lo bueno del ACE.
Se pueden establecer criterios múltiples de "matcheo", donde el más básico es de la VIP y el puerto por ejemplo, pero luego a nivel de capa 7 se podría"matchear" otros criterios adicionales como el host header, el url e incluso la direccion(es) donde fue generado el tráfico(source) y las direcciones de destino(destination), etc
Saludos,
Jorge
8 Replies 8
Jorge Bejarano
Level 4
Level 4
Hello Rogelio,
Can you share the configuration which you have done so far?
Jorge
Hi Jorge:
Actually, I have not done it yet because I can not combine the desired matching criteria.
My question is if the desired combination is feasible or not. I have not found how to do it. If you use L4 then you can´t include URLs for additional matching. If you use L7 then you can not include a VIP for additional matching.
Any hints will be greatly appreciated.
Rogelio
Hi Rogelio,
Jorge
sesoerensen
Rogelio Alvez,
Here's one way:
*/ VIP class-map
*/ URL
or
*/ Policy map
class class-default
Cheers Mate.
Sincerely,
Hello Soren!
So I can get what I want by nesting the matching criterias on two different levels (first on the class-map and then in the load-balancing policy).
thanks a lot for the hint.
Best regards, rogelio
Jorge Bejarano
Level 4
Level 4
Hola Rogelio,
No me queda claro lo que andas buscando, te refieres a una ip virtual (VIP) que lo va a buscar es concidir con url especifico para hacer el balanceo de carga especifico, o buscas "matchear" la VIP y luego algun usuario en especifico (destino). Como podras saber se pueden hacer clases que balanceen la direccion de destino, entonces no se si te refieres a eso y luego "matchear" la ip virtual y el puerto
Si solo requieres "matchear" la vip en puerto 80 y el url este seria un ejemplo, sino especifica lo que realmentes te gustaria configurar:
class-map match-all vip_balanceo_80
  2 match virtual-address 172.16.1.101 tcp eq www
policy-map multi-match clientes
  class vip_balanceo_80
    loadbalance vip inservice
    loadbalance policy poliza-capa7
policy-map type loadbalance http first-match poliza-capa7
  class poliza_url
    serverfarm intranet
  class class-default
    serverfarm web
class-map type http loadbalance match-all poliza_url
serverfarm host intranet
  rserver lnx1
    inservice
  rserver lnx2
    inservice
serverfarm host intranet-default
  rserver lnx3
    inservice
  rserver lnx4
    inservice
rserver host lnx1
  ip address 192.168.1.11
  inservice
rserver host lnx2
  ip address 192.168.1.12
  inservice
rserver host lnx3
  ip address 192.168.1.13
  inservice
rserver host lnx4
  ip address 192.168.1.14
  inservice
Saludos,
Jorge
Hola Jorge!
No sabía que se podían anidar condiciones.
Por lo que veo, en tu policy-map, vos ejecutás la primer selección (la VIP y el port TCP). Una vez en la "load-balance policy", tu puedes volver a ejecutar un nuevo matching, en este caso por la URL!
Voy a probar y hacerte saber mis resultados.
Gracias por la ayuda!!!
saludos, Rogelio
Hola Rogelio,
Saludos,
Jorge
