how to configure ntp between CDM and CE?
garyhuang
I used "ntp server xxx.xxx.xxx.xxx (CDM IP)" on the CE config mode to have the CE time synced to the CDM, however the time on the two boxes are still different. How can i make the time sync work?
Gary
owillins
Level 6
Level 6
CE gets its time and zone info from the CDM. Have you set the time on the CDM correctly? Do you have authentication configured? if so ensure the key is the same on both sides and also the cdm is configured as the ntp master.
