How to see the concurrent connection(min/current/max) count on ACE10 module?
superjini75
Hi All.
I would like to see the concurrent connection(min/current/max) count on ACE10 module.
How to see to the these information on ACE10 module?
Thanks.
ajayku2
You can try following commands :
show resource usage all ( This will show all )
if you just want to see the concurrent connection use :
show connection count
hope that helps.
regards,
Ajay Kumar
Hi Kumar
Thank you for your kind answer.
I have one question to you.
The data sheet is shown as show below.
The concurrent connection is 4,000,000 on ACE module system limit.
Is it corret?
When the 'show resource usaga all' enter, the Max con-current is 8,000,000.
Why is the difference count value?
What is the unit for value?
Thanks.
Seungjo Lee
We have 4 million connection records per IXP, and each connection record
can hold one leg of the connection. So we allow 8 million connection
records between the two IXPs, which amounts to 4 million complete
connections (including both inbound and outbound).
That explain the reason why you see "Max con-current is 8,000,000."
hope that helps,
Ajay Kumar
