sh conn (Cause of failures)
chanchan1029
Hello
Instruction:
CONN WEB server farm online sh
Failure occurs on a particular server. The cause of the failure?
sh serverfarm WEB
serverfarm     : WEB, type: HOST
total rservers : 3
                                                ----------connections-----------
       real                  weight state        current    total      failures
   rserver: WEB1
       172.32.20.11:80       8      OUTOFSERVICE 22         0          0
   rserver: WEB2
       172.32.20.14:80       8      OPERATIONAL  37         859        0
   rserver: WEB3
       172.32.20.17:80       8      OPERATIONAL  60         1168       21
There is no result to failure of the probe.
Software
  loader:    Version 12.2[120]
  system:    Version A2(3.2a) [build 3.0(0)A2(3.2a)]
Thank you.
5 Replies 5
Alex Rickard
The failure counter here could increment due to a couple reasons. One is that a SYN timeout occurs and the connection is unable to be established. A second reason is that the ACE received a RST. Another reason could be a internal exception. Typically, a packet capture would be leveraged to determine what is actually occurring during the connection lifetime that would cause the ACE to increment the "failure" counter.
-Alex
Kanwaljeet Singh
Hi Gyoun,
Are these failures increasing constantly ? Was there a probe failure?  Can you check what is the last diconnect err shown when you do show probe detail?
Kanwal
Thank you for answer.
Has now continued failure occurs. Is there to be resolved method to SYN timeout occurrence at the time?
The ace is the problem? The problem is the server?
inside_l4# sh probe 80 detail
probe       : 80
type        : TCP
state       : ACTIVE
description :
   port      : 80      address     : 0.0.0.0         addr type  : -
   interval  : 2       pass intvl  : 2               pass count : 5
   fail count: 2       recv timeout: 2
   conn termination : FORCED
   expect offset    : 0         , open timeout     : 10
   expect regex     : -
   send data        : -
                       --------------------- probe results --------------------
   probe association   probed-address  probes     failed     passed     health
   serverfarm  : WEB
     real      : WEB1[80]
                       172.32.20.11    0          0          0          DISABLED
   Socket state        :
   No. Passed states   : 0         No. Failed states : 0
   No. Probes skipped  : 0         Last status code  : 0
   No. Out of Sockets  : 0         No. Internal error: 0
   Last disconnect err :  -
   Last probe time     : Never
   Last fail time      : Never
   Last active time    : Never
     real      : WEB2[80]
                       172.32.20.14    46499      0          46499      SUCCESS
   Socket state        : CLOSED
   No. Passed states   : 1         No. Failed states : 0
   Last probe time     : Tue May 21 18:42:58 2013
   Last active time    : Mon May 20 16:46:57 2013
     real      : WEB3[80]
                       172.32.20.17    45704      0          45704      SUCCESS
   Last probe time     : Tue May 21 18:42:57 2013
   Last active time    : Mon May 20 17:13:32 2013
   serverfarm  : WEB_EDI
     real      : WEB4[80]
                       172.32.20.21    972749     3          972746     SUCCESS
   No. Probes skipped  : 1         Last status code  : 0
   Last active time    : Mon Apr 29 04:17:06 2013
     real      : WEB5[80]
                       172.32.20.24    972746     2          972744     SUCCESS
   No. Probes skipped  : 4         Last status code  : 0
inside_l4# sh serverfarm WEB
total rservers : 3
   rserver: WEB1
       172.32.20.11:80       8      OUTOFSERVICE 0          0          0
   rserver: WEB2
       172.32.20.14:80       8      OPERATIONAL  28         55085      622
   rserver: WEB3
       172.32.20.17:80       8      OPERATIONAL  5          44150      414
MINISTOP/inside_l4#
From your output Web1, 2, and 3 have not failed any probes. To determine what is actually occuring, gather a simultatneous packet capture on the ACE and on the server while the issue is occurring. You want to make sure that the failure counter is incrementing when the capture is taken. Another way to focus in would be to determine what, if any, symptoms the client sees while the issuing is occurring. This could help you to hone in on where to look. Once you get the captures, anaylze them to find the problem traffic and determine the cause.
Alex
hi
Normalization Results confirm
MINISTOP/inside_l4# show np 1 me-stats "-s norm"
Normalization Statistics: (Current)
[Drops] TCP invalid conn miss flags:         283038             0
TCP no of cleared options:                        4             0
[Drops] TCP non-syn options on syn:               7             0
[Drops] fp TCP RST has wrong ack:                 1             0
(Context 3 Statistics)
[Drops] fp TCP normalization:                283042             0
increase in count
Phenomenon occurs, what is the problem?
Thank you
