How to use debug on CSM SSL module?
dcayer
I'm installing a new CSM with SSL module (WS-X6066-SLB-S-K9) and can't get the debugs to work. Acutally, I enabled debugging (to troubleshoot SSL Handshake problems) but nothing shows up on the screen or in the log. Any ideas?
mcbconmrk105d1z2-ssl#show debugging
STE Mgr:
STE SSL Pkt debugging is on
STE SSL Handshake events debugging is on
STE SSL Alert events debugging is on
STE SSL detailed debugging is on
STE SSL error events debugging is on
SSL Subsystem:
SSL Handshake Message debugging is on
SSL Traffic debugging is on
SSL Error debugging is on
SSL Event debugging is on
mcbconmrk105d1z2-ssl#show log
Syslog logging: enabled (0 messages dropped, 31 messages rate-limited, 0 flushes, 0 overruns, xml disabled)
Console logging: level debugging, 254 messages logged, xml disabled
Monitor logging: level debugging, 241 messages logged, xml disabled
Logging to: vty4(0)
Buffer logging: level debugging, 284 messages logged, xml disabled
Logging Exception size (8192 bytes)
Count and timestamp logging messages: disabled
Trap logging: level informational, 324 message lines logged
Thanks in advance,
Daniel
Gilles Dufour
the debug messages are displayed on a different console. The console is different depending on the type of debug.
telnet 2001 ? FDU cpu
telnet 2002 ? TCP cpu
telnet 2003 ? SSL cpu
Gilles.
