I can not ping VIPs
alashmoury
Dear All
We have tow Cisco ACE 4710, one (ACE-1) for load balancing OCS Frontend servers and the other (ACE-2) for load balancing OCS edge servers, after doing the following configuration we could not ping the VIPs (10.x.1.55 and 172.16.x.20).
could you please check this configuration and help me to solve this issue?!
hostname ACE-1
interface gigabitEthernet 1/1
  switchport access vlan 1000
  no shutdown
interface gigabitEthernet 1/2
  speed 1000M
  duplex FULL
  switchport trunk allowed vlan 100
  no shutdown
interface gigabitEthernet 1/3
  no shutdown
interface gigabitEthernet 1/4
  switchport access vlan 500
  no shutdown
access-list ALL line 8 extended permit ip any any
access-list qqq line 8 extended permit icmp any any
probe tcp FQDN-CWA-1
  ip address 10.x.1.53 routed
  interval 15
  passdetect interval 60
  open 1
probe tcp FQDN-CWA-2
  ip address 10.x.1.54
  interval 15
  open 1
probe tcp FQDN-OCSPool-3
  ip address 10.x.1.51
  interval 15
  open 1
probe tcp FQDN-OCSPool-4
  ip address 10.x.1.52 routed
  interval 15
  open 1
probe icmp FQDN-ocspool-1
  description monitoring probe for the first FQDN-ocspool server
  ip address 10.x.1.51 routed
  interval 5
  passdetect interval 10
  passdetect count 2
  receive 5
probe icmp FQDN-ocspool-2
  description monitoring probe for the second FQDN-ocspool server
  interval 5
  passdetect count 2
  receive 5
probe tcp OCE01
  ip address 172.16.x.9 routed
  port 443
  interval 15
  open 1
probe tcp OCE02
  ip address 172.16.x.10 routed
  port 443
  interval 15
  open 1
rserver host FQDN-CWA-1
  inservice
rserver host FQDN-CWA-2
  inservice
rserver host FQDN-ocspool-1
  inservice
rserver host FQDN-ocspool-2
  inservice
rserver host OCE01
  conn-limit max 4000000 min 4000000
  inservice
rserver host OCE02
  inservice
serverfarm host FQDN-CWA-servers
  description this server farm load-balances between FQDN-CWA-1 and FQDN-CWA-2
  rserver FQDN-CWA-1
    probe FQDN-CWA-1
    inservice
  rserver FQDN-CWA-2
    probe FQDN-CWA-2
    inservice
serverfarm host FQDN-OCSPool-Servers
  rserver FQDN-ocspool-1
    probe FQDN-OCSPool-3
    inservice
  rserver FQDN-ocspool-2
    probe FQDN-OCSPool-4
    inservice
serverfarm host OCE
  description This serverfarm is for OCE01&2
  rserver OCE01
    probe OCE01
    inservice
  rserver OCE02
    probe OCE02
    inservice
class-map match-all FQDN-CWA
  2 match virtual-address 10.x.1.56 any
class-map match-all FQDN-OCSPool
  2 match virtual-address 10.x.1.57 any
class-map match-all L4VIPCLASS
  2 match virtual-address 10.x.1.55 any
class-map type management match-any remote_access
  2 match protocol xml-https any
  4 match protocol telnet any
  5 match protocol ssh any
  6 match protocol http any
  7 match protocol https any
  8 match protocol snmp any
policy-map type management first-match remote_mgmt_allow_policy
  class remote_access
    permit
  class class-default
    permit
policy-map type loadbalance first-match FQDN-CWA
  class class-default
    serverfarm FQDN-CWA-servers
policy-map type loadbalance first-match FQDN-OCSPool-l7slb
  class class-default
    serverfarm FQDN-OCSPool-Servers
policy-map type loadbalance first-match OCE
  class class-default
    serverfarm OCE
policy-map multi-match VIPs
  class L4VIPCLASS
    loadbalance vip inservice
    loadbalance policy OCE
    loadbalance vip icmp-reply active
  class FQDN-CWA
    loadbalance policy FQDN-CWA
    nat dynamic 1 vlan 100
  class FQDN-OCSPool
    loadbalance policy FQDN-OCSPool-l7slb
interface vlan 100
  ip address 10.x.1.110 255.255.255.0
  access-group input ALL
  access-group output ALL
  nat-pool 1 10.x.1.240 10.x.1.249 netmask 255.255.255.0 pat
  service-policy input remote_mgmt_allow_policy
  service-policy input VIPs
  no shutdown
interface vlan 500
  ip address 10.x.5.1 255.255.255.0
  no shutdown
interface vlan 600
  ip address 10.x.6.4 255.255.255.0
  no shutdown
interface vlan 1000
  ip address 1.1.1.1 255.255.255.0
  no shutdown
ip route 0.0.0.0 0.0.0.0 10.x.5.2
ip route 10.x.2.0 255.255.255.0 10.x.5.2
ip route 78.x.x.240 255.255.255.240 10.x.5.2
Status     : ACTIVE
Description: -
Interface: vlan 1 100
  service-policy: VIPs
    class: FQDN-CWA
      nat:
        curr conns       : 0         , hit count        : 41
        dropped conns    : 0
        client pkt count : 2788      , client byte count: 904455
        server pkt count : 7311      , server byte count: 9541139
        conn-rate-limit      : 0         , drop-count : 0
        bandwidth-rate-limit : 0         , drop-count : 0
     VIP Address:    Protocol:  Port:
     10.x.1.56      any
      loadbalance:
        L7 loadbalance policy: FQDN-CWA
        VIP ICMP Reply       : ENABLED-WHEN-ACTIVE
        VIP State: INSERVICE
        Persistence Rebalance: DISABLED
        dropped conns    : 0
        L7 Loadbalance policy : FQDN-CWA
          class/match : class-default
            LB action :
               primary serverfarm: FQDN-CWA-servers
                    state: UP
                backup serverfarm : -
            hit count        : 41
            dropped conns    : 0
            compression      : off
      compression:
        bytes_in  : 0
        bytes_out : 0
        Compression ratio : 0.00%
Status     : ACTIVE
Description: -
    class: FQDN-OCSPool
      nat:
        curr conns       : 15        , hit count        : 6757
        dropped conns    : 105
        client pkt count : 735221    , client byte count: 207648039
        server pkt count : 496785    , server byte count: 73460926
     10.x.1.57      any
      loadbalance:
        L7 loadbalance policy: FQDN-OCSPool-l7slb
        curr conns       : 15        , hit count        : 7061
        dropped conns    : 370
        client pkt count : 735618    , client byte count: 207669423
        L7 Loadbalance policy : FQDN-OCSPool-l7slb
            LB action :
               primary serverfarm: FQDN-OCSPool-Servers
                    state: UP
            hit count        : 6800
            dropped conns    : 0
            compression      : off
      compression:
        bytes_in  : 0
        bytes_out : 0
Status     : ACTIVE
Description: -
    class: L4VIPCLASS
     10.x.1.55      any
      loadbalance:
        L7 loadbalance policy: OCE
        VIP state: OUTOFSERVICE
        curr conns       : 0         , hit count        : 6
        dropped conns    : 6
        client pkt count : 6         , client byte count: 839
        server pkt count : 0         , server byte count: 0
        L7 Loadbalance policy : OCE
            LB action :
               primary serverfarm: OCE
                    state: DOWN
            hit count        : 0
            dropped conns    : 0
            compression      : off
      compression:
        bytes_in  : 0
        bytes_out : 0
hostname ACE-2
  description connection to the ASA
  switchport access vlan 300
  no shutdown
  description trunk with DELL SW module A1
  switchport trunk allowed vlan 200,250,600
  no shutdown
  no shutdown
  no shutdown
context Admin
  member Sticky
access-list anyone line 8 extended permit ip any any
access-list qqq line 8 extended permit ip any host 10.x.2.3
access-list qqq line 16 extended permit ip host 10.x.2.3 any
probe tcp Edge-1
  ip address 78.x.x.244 routed
  port 443
  interval 15
  open 1
probe tcp Edge-2
  ip address 78.x.x.245 routed
  port 443
  interval 15
  open 1
probe tcp Edge-3
  ip address 78.x.x.246 routed
  port 443
  interval 15
  open 1
probe tcp Edge-4
  ip address 78.x.x.250 routed
  port 443
  interval 15
  open 1
probe tcp Edge-5
  ip address 78.x.x.251 routed
  port 443
  interval 15
  open 1
probe tcp Edge-6
  ip address 78.x.x.252 routed
  port 443
  interval 15
  open 1
probe tcp FrontEnd-01
  port 5061
  interval 15
  open 1
probe tcp FrontEnd-02
  port 5061
  interval 15
  open 1
rserver host DTSHQ-1
  inservice
rserver host DTSHQ-2
  inservice
rserver host DTSHQ-3
  inservice
rserver host DTSHQ-4
  inservice
rserver host DTSHQ-5
  inservice
rserver host DTSHQ-6
  inservice
rserver host DTSHQ-OCE01
  inservice
rserver host DTSHQ-OCE02
  inservice
rserver host FrontEnd-01
  ip address 10.x.1.10
  inservice
rserver host FrontEnd-02
  inservice
serverfarm host DTSHQ-servers
  rserver DTSHQ-1
    probe Edge-1
    inservice
  rserver DTSHQ-4
    probe Edge-4
    inservice
serverfarm host DTSHQ-servers1
  rserver DTSHQ-2
    probe Edge-2
    inservice
  rserver DTSHQ-5
    probe Edge-5
    inservice
serverfarm host DTSHQ-servers2
  rserver DTSHQ-3
    probe Edge-3
    inservice
  rserver DTSHQ-6
    probe Edge-6
    inservice
serverfarm host FrontEnd
  rserver FrontEnd-01
    probe FrontEnd-01
    inservice
  rserver FrontEnd-02
    probe FrontEnd-02
    inservice
sticky ip-netmask 255.255.255.240 address source Internet-Users
  timeout 180
  timeout activeconns
  serverfarm DTSHQ-servers
sticky ip-netmask 255.255.255.240 address source Internet-Users1
  timeout 180
  timeout activeconns
  serverfarm DTSHQ-servers1
sticky ip-netmask 255.255.255.240 address source Internet-Users2
  timeout 180
  timeout activeconns
  serverfarm DTSHQ-servers2
class-map match-all FrontEnd
  2 match virtual-address 172.16.x.20 any
class-map match-all L4VIPCLASS-1-any
  2 match virtual-address 10.x.2.4 any
class-map match-all L4VIPCLASS-2-any
  2 match virtual-address 10.x.2.5 any
class-map match-all L4VIPCLASS-any
  2 match virtual-address 10.x.2.3 any
  class remote_access
    permit
  class class-default
    permit
policy-map type loadbalance first-match DTSHQ-servers
  class class-default
    sticky-serverfarm Internet-Users
policy-map type loadbalance first-match DTSHQ-servers1
  class class-default
    sticky-serverfarm Internet-Users1
policy-map type loadbalance first-match DTSHQ-servers2
  class class-default
    sticky-serverfarm Internet-Users2
policy-map type loadbalance first-match FrontEnd
  class class-default
    serverfarm FrontEnd
policy-map multi-match DTSHQ-servers-LB
  class L4VIPCLASS-any
    loadbalance policy DTSHQ-servers
  class L4VIPCLASS-1-any
    loadbalance policy DTSHQ-servers1
  class L4VIPCLASS-2-any
    loadbalance policy DTSHQ-servers2
policy-map multi-match L4FrontEnd
  class FrontEnd
    loadbalance policy FrontEnd
interface vlan 200
  ip address 78.x.x.243 255.255.255.240
  access-group input anyone
  access-group output anyone
  no shutdown
interface vlan 250
  ip address 172.16.x.98 255.255.255.0
  service-policy input L4FrontEnd
  no shutdown
interface vlan 300
  description communication vlan with the ASA
  ip address 10.x.2.2 255.255.255.0
  service-policy input DTSHQ-servers-LB
  no shutdown
interface vlan 500
  description Connection to ACE-1
  ip address 10.x.5.2 255.255.255.0
  no shutdown
interface vlan 600
  ip address 10.x.6.3 255.255.255.0
  no shutdown
ip route 0.0.0.0 0.0.0.0 10.x.2.1
ip route 10.x.1.0 255.255.255.0 10.x.5.1
Status     : ACTIVE
Description: -
Interface: vlan 1 250
  service-policy: L4FrontEnd
    class: FrontEnd
     172.16.x.20    any
      loadbalance:
        L7 loadbalance policy: FrontEnd
        curr conns       : 0         , hit count        : 5
        dropped conns    : 5
        client pkt count : 5         , client byte count: 610
        L7 Loadbalance policy : FrontEnd
            LB action :
               primary serverfarm: FrontEnd
                    state: DOWN
            hit count        : 0
            dropped conns    : 0
            compression      : off
      compression:
        bytes_in  : 0
        bytes_out : 0
Status     : ACTIVE
Description: -
Interface: vlan 1 300
  service-policy: DTSHQ-servers-LB
    class: L4VIPCLASS-1-any
     10.x.2.4       any
      loadbalance:
        L7 loadbalance policy: DTSHQ-servers1
        curr conns       : 0         , hit count        : 1461
        dropped conns    : 96
        client pkt count : 19015     , client byte count: 3214677
        server pkt count : 18643     , server byte count: 6141422
        L7 Loadbalance policy : DTSHQ-servers1
            LB action :
               sticky group: Internet-Users1
                  primary serverfarm: DTSHQ-servers1
                    state: UP
            hit count        : 1441
            dropped conns    : 0
            compression      : off
      compression:
        bytes_in  : 0
        bytes_out : 0
Status     : ACTIVE
Description: -
    class: L4VIPCLASS-2-any
     10.x.2.5       any
      loadbalance:
        L7 loadbalance policy: DTSHQ-servers2
        curr conns       : 0         , hit count        : 1087
        dropped conns    : 67
        client pkt count : 10309     , client byte count: 1285741
        server pkt count : 10098     , server byte count: 1758646
        L7 Loadbalance policy : DTSHQ-servers2
            LB action :
               sticky group: Internet-Users2
                  primary serverfarm: DTSHQ-servers2
                    state: UP
            hit count        : 1085
            dropped conns    : 0
            compression      : off
      compression:
        bytes_in  : 0
        bytes_out : 0
Status     : ACTIVE
Description: -
    class: L4VIPCLASS-any
     10.x.2.3       any
      loadbalance:
        curr conns       : 0         , hit count        : 1021
        dropped conns    : 71
        client pkt count : 14750     , client byte count: 1636324
        server pkt count : 12807     , server byte count: 5138009
            LB action :
                    state: UP
            hit count        : 1021
            dropped conns    : 0
            compression      : off
      compression:
        bytes_in  : 0
        bytes_out : 0
17 Replies 17
You want to reach your VIPs over VLAN 500, why not put your service-policy there?
interface vlan 500
  no shutdown
Hi Marko
I tried it but it did not work
best regards,
alashmoury
Hi All
Do you think it's logical to connect tow load balancers together directly by cable as uplink switches or we should connect them by switche?
