IOS SLB - Load balancing a vserver
irodi
I want to know if Ia can do load balancing with IOS towards a Vserver. I mean if I have a server farmA: real1=10.10.10.1 and real2=20.20.20.1, the vserver is 30.30.30.1. Could I have another vserver=20.20.20.1 (the second real of server farmA) with another serverfarmB?
Ira
Gilles Dufour
I'm not sure what would be the interest of doing so ?
Just add the reals from the 2nd serverfarm into the first one.
What is the ultimate goal here ?
The answer to your question is : no - this is not possible.
Gilles.
Thanks for rating this answer.
Hi Gilles,
you are right but I need to do same sticky table with different server farm and as you know this is not possible with IOS.
I need to send accounting traffic to three real server, the same for tcp traffic, but just to only two real for the udp traffic. All of this kind of traffic must follow the same sticky table. In attach you will find a small doc with the explain of I would lik to do. If you have any other solution It would be ok for me
Ira
