is it possible to log in to ACE module on 6509
gargolek99
We have run into the issue where we are unable to log in to ACE which is module on 6509 from outside. Is it possible to log in to ace module from switch itself from 6509?
I have tried remote login and remote command nothing worked...?
Kanwaljeet Singh
Did you try "session slot x processor 0". X would be the slot in which you have ACE module. Show module on switch should show that.
If the ACE is in ROMMON mode you can follow the below link for remote login and boot.
http://docwiki.cisco.com/wiki/Cisco_Application_Control_Engine_%28ACE%29_Troubleshooting_Guide_--_Troubleshooting_ACE_Boot_Issues
Kanwal
Kanwaljeet Singh
Kanwal
gargolek99
That worked thank you so much for quick help.
I am glad it helped you.
You are welcome!
Kanwal
