Is the ACE limiting how traffic per session ?
ksudi
I am doing a bandwidth test between 2 data centers and wondering if there is a default session limitation on the ACE.
Karar
Gilles Dufour
for one single connection you mean ?
The answer is no.
There is a BW limitation for the context and you can see if there is any drop with the 'show resource usage'.
But there is no limit per connection.
Gilles.
Gilles Dufour
The answer is no.
Gilles.
Thanks Gilles
