Issue with ACE HTTP class map
ppatki
Community Member
This is what I want to achieve USING the ACE as a reverse proxy.
User uses the url https://abc/password - gets to the destination server & the web page
If user tries to use any thing additional then the connection is dropped at the ACE such as
https://abc/password/test or any such variation.
Following is the config I have to achieve this
class-map type http loadbalance match-any L7-CLASS-TEST
  match http url /password
  match http url /password/
class-map type http loadbalance match-any L7-CLASS-TEST-deny
  2 match http url .*.*
policy-map type loadbalance first-match LBP-TEST
  class L7-CLASS-TEST
    serverfarm FARM-TEST
    ssl-proxy client TEST
  class L7-CLASS-TEST-deny
    drop
  class class-default
The problem with this is when the page opens I get broken links on all the images. If I use the following line
match http url /password.*
I get the images to work but the user can use the https://abc/password/test which is not what I want.
Has any one faced this issue ?
Any help will be appreciated.
Thanks in advance
Prasanna
Jorge Bejarano
Level 10
Level 10
Prasanna,
What about if you try it in HTTP and apply the following change?
  2 match http url /.*
This should work in HTTP but not with HTTPS
Anyway, it should not work since everything seems to be encrypted, you may require either SSL-termination or END-TO-END SSL for this then the ACE can decrypt the request see what it needs to do and take the load balance decision.
Jorge
Jorge Bejarano
Level 10
Level 10
Prasanna,
Jorge
The issue was with allowing the image files. I allowed all the image file types in the permit class map in addition to the ones i have permitted already. That now workes.
My appologies i by mistake enabled the tab of correct answer for the privious comment from jorge
