Issue with Source NAT on ACE
nlkarthik
Hello All,
I face an issue while creating source nat on cisco ACE. There is already a default source nat ip for the context. I created a new one for smtp traffic alone. Iam facing issues in prefixing the newly created nat-pool rule(nat-pool 100) above the default one (nat-pool 2257) on the external gateway interface as its not placing that on top ,due to which only the default snat ip is getting shown on all servers. Can someone assist on this.
interface vlan 1137
  description outside interface gateway
  ip address 10.103.226.253 255.255.255.248
  alias 10.103.226.252 255.255.255.248
  peer ip address 10.103.226.254 255.255.255.248
  access-group input internet
  access-group output all
  nat-pool 2257 209.34.80.240 209.34.80.240 netmask 255.255.255.255 pat >>>
  nat-pool 100 209.34.80.246 209.34.80.246 netmask 255.255.255.255 pat >>>>
  service-policy input VIPS
  service-policy input INSPECTION_POLICY
  service-policy input remote-mgmt
  no shutdown
regards,
Karthik
pablo.nxh
Level 3
Level 3
Hi Karthik,
NAT is not applied in order based on lower/higher ID under the interface, in this case your NAT pool 2257 is taking precedence because it must be applied for the VIP doing the load balance either under the multi-match policy or the fist-match policy level.
i.e
policy-map multi-match LB
class VIP
    loadbalance vip inservice
    loadbalance policy Web
    nat dynamic 2257 vlan 1137
If you want to change this behavior just swap the natpool ID under this section (keep in mind this will kill the the active connections).
__ __
Pablo
