Load Balancing Citrix Servers
dschleyer
who has expierence wtih load balancing Citrix servers using a CSS-Switch ?
How does the config look like ?
regards
Dietrich Schleyer
a-vazquez
Level 6
Level 6
The following docs would give you the basic steps to configure loadbalancing on the CSS. However it is not specific to Citrix servers, the example refers to web servers but they'd hold good for the Citrix servers too. All the best!!!http://www.cisco.com/warp/public/117/basic_css_lb_config.html
http://www.cisco.com/warp/public/117/methods_load_bal.html
