max-reserved-bandwidth 100% for the interface
kevintang
Level 4
Level 4
According to CCO as following text, the remaining 25 percent of bandwidth is used for overhead, including Layer 2 overhead, control traffic, and best-effort traffic. I want to know why cisco choose 25 percent. why not 30% or 20%?
If I config the max-reserved-bandwidth 100% for the interface, does it will effect the routing protocol? also effect the network conectivity?
thanks for your answer
Usage Guidelines for max-reserved-bandwidth
The sum of all bandwidth allocation on an interface should not exceed 75 percent of the available bandwidth on an interface. The remaining 25 percent of bandwidth is used for overhead, including Layer 2 overhead, control traffic, and best-effort traffic.
If you need to allocate more than 75 percent for RSVP, CBWFQ, LLQ, IP RTP Priority, Frame Relay IP RTP Priority, and Frame Relay PIPQ, you can use the max-reserved-bandwidth command. The percent argument specifies the maximum percentage of the total interface bandwidth that can be used.
If you do use the max-reserved-bandwidth command, make sure that not too much bandwidth is taken away from best-effort and control traffic.
The max-reserved-bandwidth command is intended for use on main interfaces only; it has no effect on virtual circuits (VCs) or ATM permanent virtual circuits (PVCs).
Gilles Dufour
Kevin,
this is the wrong group for this question.
Gilles.
