migrate from sca11000 to css with ssl module
bjelf
Hi, I'm migrating from a css11151 & sca11000 to
a css11506 with an ssl module. Is there a doc
or can anyone recommend a way to export the certs & keys from the sca and import them on the css?
I've tried cutting & pasting from the sca configs to key.der files and then improting those to the css but I just get "%% File does not contain an RSA key" when I try "ssl associate".
jfoerster
Level 4
Level 4
well I think you are not able to export certificates from the SCA because as far as I know you are not able to create certificates on the SCA but you can import them (see http://www.cisco.com/en/US/products/hw/contnetw/ps2083/products_configuration_guide_chapter09186a0080087668.html#xtocid15)
Having a look at the rest of this guide there are only explanations on how to import certificates but non for creating nor for exporting.
Sorry about that.
Kind Regards,
Joerg
