Mirror single ACE context
johnmillbrandeis
Community Member
Hello everyone,
I'm setting up a load-balanced DNS environment, and would like to mirror all of our DNS traffic to a statistics collection and monitoring server.  Our setup is pretty simple--just load-balance udp port 53 traffic to a single serverfarm (4 rservers) using one VIP (I've gotten both transparent LB and routed LB/static NAT working).  Is there some way within a context to do this?  By creating a second context?  Or does this need to happen outside of the ACE?  I'm by no means a networking guru, so any help (even if it seems obvious) would be appreciated.
I'm using an ACE 30 module in a 6500 switch.
John
Amir Asfandyarov
Hello John,
If I correctly understood, you want to "mirror" (so, to have an exact copy of DNS traffic) hitting ACE, is this correct?
If so, take a look at this article https://supportforums.cisco.com/docs/DOC-15652 , which describes how to set up a SPAN capture from ACE internal interface.
Note you can filter on VLAN (that is, redirect/capture traffic on particular front-end/back-end VLAN. A bit tricky to make additional filtering on ports/protocols, though... Take a look at VACL captures in the same article as well.
HTH, Amir
