NAT Issue
lingaraj19
Community Member
when client and servers are resides in same vlan, we are not able to access the application on VIP but the same time clients in different vlan can access the application on VIP.
why this is happening please can any one help me out in this.
Lingaraj
abinjola
I assume you've configured ACE in one-arm.With regards to client/server in same subnet, can you please try the following:
a)NAT the source clients to VIP address and see if it works
b)Disable randomisation just to check if it works.
c)Are you able to telnet to VIP on that you trying to access ?
After you try the above suggestion and if it doesnt work, upload the config here.
