Need help with adding diff port numbers in css 11503
skkghello1
Community Member
Hi ,
Below is my exisisting config of css 11503 --working all correctly on port== 9004.
service abc1--9004
  ip address 10.10.10.17
  protocol tcp
  port 9004
  redundant-index 33
  keepalive frequency 2
  keepalive maxfailure 2
  keepalive retryperiod 2
  keepalive port 9004
  keepalive type tcp
  active
service abc2--9004
  ip address 10.10.20.14
  protocol tcp
  port 9004
  redundant-index 36
  keepalive port 9004
  keepalive type tcp
  active
content ab1-9004
    vip address 10.10.150.12
    port 9004
    protocol tcp
    redundant-index 53
    balance weightedrr
    advanced-balance sticky-srcip
    flow-timeout-multiplier 451
    add service abc1--9004 weight 10
    add service abc2--9004 weight 1
    active
  content ab2-9004
    vip address 10.10.150.13
    port 9004
    protocol tcp
    redundant-index 60
    balance weightedrr
    add service abc2--9004 weight 10
    active
group nat-abc
  vip address 10.10.150.16
  redundant-index 54
  add destination service abc1--9004
  add destination service abc2--9004
  active
_____________________________________________________________________________
Question:
I have to add another port number 9005 for the above config. New port==8004
Can you please check my new config :
Config t
when you enter
service abc1-8004
  ip address 10.10.10.17  -- i am using the same ips as above but diff port number--is it correct
  protocol tcp
  port 8004
  redundant-index 133----------------- can i use any  number which is not already used--- in the redundant-index
  keepalive port 8004
  keepalive type tcp
  active
exit
service abc2-8004
  protocol tcp
  port 8004
  redundant-index 136
  keepalive port 8004
  keepalive type tcp
  active
exit
content ab1-8004
    vip address 10.10.150.12 -- i am using the same ips as above but diff port number --is it correct
    port 8004
    protocol tcp
    redundant-index 153
    balance weightedrr
    add service abc1-8004 weight 10
    add service abc2-8004 weight 1
    active
content ab2-8004
    protocol tcp
    port 8004
    redundant-index 160
    balance weightedrr
    add service abc2-8004 weight 10
    active
Adding the service to the same group
group nat-abc
  vip address 10.10.150.16   --what does this vip do ? (snat)
  redundant-index 54
  add destination service abc1-8004-----should i add them here
  add destination service abc2-8004-----should i add them here
  active
or  I have to creat a new group
group nat-abc2
  vip address 10.10.150.17 --with diff ip
  redundant-index 254
  active
Daniel Arrondo Ostiz
Hi Keo,
Let's go through your questions one by one:
  • It's fine to create a new content rule with the same IP but a different port. The same applies to the services
  • The redundant-index needs to be a unique number for each service. This number is just an identifier so it doesn't matter which one is used.
  • If you add all the services under one single source group, all connections will be natted to the same IP regardless of which content rule they hit. If you need this IP to be different, then you will have to create separate groups.
I hope this answers all your questions, but, please, do not hesitate to contact me again if you need further clarification.
Daniel
Hi Keo,
Daniel
