X-Forward not supported by HTTP/S?
taralczak
We're trying to set up ACE as described in document ID 107399 with the goal to have the IP address of the connecting HTTP clients inserted as the "X-FORWARD" attribute in the HTTP header. With HTTP it works but with HTTP/S it doesn't. Is this feature effectively limited to unsecure HTTP clients?
Daniel Arrondo Ostiz
Hi Jan,
It is possible to insert headers/cookies into a HTTPS connection, but, to do that, the ACE needs to be able to decrypt the traffic. It's what we call end-to-end SSL termination.
There is an example on cisco.com that explains how to configure this. The example is inserting cookies, but, inserting the x-forwarded header would be equivalent. See the link below for more details:
http://www.cisco.com/en/US/products/hw/modules/ps2706/products_configuration_example09186a00809c6f37.shtml
With this kind of configuration, the ACE will first terminate the SSL connection to decrypt the traffic, then do any kind of L7 processing (parsing the HTTP header, inserting headers or cookies, rewriting URLs...) and, once it has finished all the processing and chosen a real server to handle the connection, it will open a new SSL connection to the server and send the request encrypted again.
Please, do not hesitate to contact me again if you still have questions after going through the example.
Daniel
Hi Jan,
Daniel
