Need to specific bypass rules on CE-550
mter-oganesyan
I have a few client groups traffic-shaped on a router. The same router forward http packets with wccp2 to CE-550. I need to bypass specific http requests, for example, requests to ".zip" or ".mp3" urls (not only servers ip addressess). This packets must be returned to router, and client will make connection from itself, not from CE ip address. Not a mystic, i only need working traffic-shape on huge requests. Is it possible ?
Gilles Dufour
not possible with WCCP.
I mean you can't match on url for bypassing request. Only ip addresses.
You could do this with a CSS and have better control of the traffic sent to the Cache.
Finally, if the problem is the ip address used by the Cache, you can configure
'wccp spoof-client-ip enable' so the CE uses the client ip address to make its own request.
Gilles.
I haven't this command my CE-550 ver 2.51
Is there any more ways to fix it ? Problem is the ip addred used by the Cache.
there is no solution for this on your CE.
As I said, you can replace the router with a CSS and then you can do it.
Gilles.
