New Edge Device (672) Addition in Existing Infra.
ajay chauhan
Level 7
Level 7
Hi All.
I have WAAS infra running with CM-612 and Edge-512 running on WCCP v2.
I want to add one more device for a location in existing infra of WAAS.Need steps to add this new device what configuration will be required.
Another question i have i added so many users with admin rights but when i give show run command on CM i am not able to see all of them.
I also want to know show run and show start only shows me some configuration like tacacs ,interface,mode of device and local user DB.
how to take backup of whatever the configuration is on WAAS box like profile in case if it dies how to restore in working condition.
Thanks in Advance for Help.
Ajay
smnambia
Hi Ajay,
If you want to add one more wae device for wccp redirection,following documentation links will assist answer the question.In short its the same set of steps that you did to configure wccp for your edge device
http://www.cisco.com/en/US/docs/app_ntwk_services/waas/waas/v431/configuration/guide/traffic.html#wp1041613
To view user accounts from CM click on My WAN > Manage Devices and click the Edit icon next to the device for which you want to view users. Then click Device Users or CM Users, depending on whether the device is an application accelerator or a Central Manager. The Users for device window displays all the user accounts defined for the device.
If the the above CM gui is showing you the users then even the cli should show the same users.When you type sh run | i username command you should see all the the users that you see on the CM gui under the CM device CM users.
More information on user accounts you can get from
http://www.cisco.com/en/US/docs/app_ntwk_services/waas/waas/v431/configuration/guide/usrmgmt.html#wp1042548
One the CM wae device in the gui and cli you should see all the users created from MY WAN--Admin---AAA---Users section.On the Application Accelerators wae's you will only see the users that have roles assigned to them.
Following link explains the Back-up procedure for CM and wae devices
http://www.cisco.com/en/US/docs/app_ntwk_services/waas/waas/v431/configuration/guide/maint.html#wp1113704
Hope the above information helps
-Smita
smnambia
Hi Ajay,
-Smita
Thanks Smita.
Hi Smita,
I added the new WAE and it seems to configured correctly ..registered with CM and downloaded all the stuff when i am putting redirect ACL it does show me data is being redirected to WAE on router...but only thing I am not able to troubleshoot is peering issue ..it does not show me peer status with others.
Any suggestion ?
If required I can send you output of commands.Please do let me know.
Ajay
