Nexus 7K & VDC Question
Steev112
                   Hi All,
I have two N7k and I want to configure two VDC each VDC has different VTP and enable OSPF between the two VDCs by using four links my questions are:
Steev112
Sorry i forget to add my question:)
  • •1.       How configure keep-alive link for each VDC to solve peer-link failure, does the configuration using management port for VDC there special configuration.
  • •2.       What is the best configuration for VDC?
  • •3.       To connect the two VDC the domain number must be different?
  • •4.       I want to configure L3 between two VDCs and enable OSPF how can achieve this task?
  • •5.       Two connect Cisco 6513 to VDC the spanning tree protocol must change to RSTP on C6513.
Hi Steven,
Sorry but you have asked this question in a wrong community. Please post this question to "Lan switching" or "other data center subjects" community for quick answer.
Kanwal
