NME-WAE-502 for point to point ?
ahzgid
Can I use two NME-WAE-502 for a point-to-point WAN, one as edge and one as core ?
Is it also possible to use them without the Central-Manager ?
Thanks !
Felix Arrieta
Hello Daniele,
here are my comments:
There is no restriction where to install them but these are design mainly for branch offices, my suggestion is to give your best guess and estimate number of users, applications, bandwidth and take the time to check the design guides as well. Request assistance to your Cisco Partner too.
some details about the module:
NME-WAE-502
Max Optimized TCP Connections: 500
Max CIFS Sessions: 120
Max Recommended WAN Link [Mbps]:4
further details can be found on the design guide
http://www.cisco.com/en/US/docs/solutions/Enterprise/Data_Center/WAASDC11.html
WAAS continues to function in the event  of CM failure, but you  need it for configuration changes, monitoring, statistics, software updates...etc.
hope that helps,
Felix
