PIX 7.2 (1) upgrade - dispacth unit
mattbclarke
I have recently upgraded one of our pixes from 6.3 (4) to 7.2(1) the unit is a 515UR with 128MB memory.
However since I have upgraded I have notices that the CPU usage has ramped up contatntly around 25% and sometimes around 40% for a consiserable amount of time.
I have been looking at 'sh proc' and 'sh proc cpu-hog' and I can see that 'dispatch unit' takes up most of the cpu.
Is it possible someone can advise me what this is? Also would you advise a bigger unit?
Matt
Process: Dispatch Unit, NUMHOG: 1639, MAXHOG: 508, LASTHOG: 510
LASTHOG At: 15:01:10 UTC Oct 23 2006
PC: 2f1dce
Traceback: 2f1b30 2f568c 2ee167 745cba 73b465 c2d5e5 c2db14
c2df24 73b20b 745fbf 74802d 626e15 21852a 11302f
Gilles Dufour
you're on the wrong forum.
We don't cover pix or security.
This one is for application loadbalancing/caching.
Gilles.
d.haeni
Level 4
Level 4
Matt,
even though it's on the wrong forum: you probably have hit a bug. I have the same issue as you with 7.2(1.9) and ASA5520. In Bug Navigator you can find tons of open bugs.
Hope this helps
/David
CSCsg38186 ASA-5520 7.2.1(1.19) crash dispatch unit
CSCsg49825 Traceback in Thread Dispatch Unit (Old pc 0x00218bc7 ebp 0x01853738)
CSCsg42272 Traceback in Dispatch Unit, assert t->stack[0] == STKINIT failed ?
CSCsg40678 Active PIX in failover pair crashed at Dispatch Unit
CSCsg06300 PIX crash fequently with Thread Name: Dispatch Unit
CSCse61850 Reload with Thread Name: Dispatch Unit; eip==q931_utl:q931_parse+154
CSCsg15416 Traceback in Dispatch Unit - w/ vpn-filter applied to IPSec connection
CSCsf32050 ASA reloads in Dispatch Unit thread
CSCsg08725 Crash in Dispatch Unit while timing out TCP keepalive message
