Poll CPU load through SNMP on CSS11152
yolo230985
I poll the 5 minute CPU load average through SNMP using the following OID: 1.3.6.1.4.1.2467.1.34.17.1.14.5.1 but it does not seem to me that is a 5 minute average, the vallue changes every second. Should I use a different OID? Τhe version is 6.10 Build 405.
b.speltz
Level 4
Level 4
If you have SNMP enabled on a CSS 11152, by using MRTG to gather SNMP data on the unit.
SNMP MIB numeric definations
**********************FOR CPU*********************
For Instantaneous CPU load:
ASN Name: apChassisMgrExtSubModuleCPUInstantaneous
Object Identifier: 1.3.6.1.4.1.2467.1.34.17.1.13
Index Value: .
Description: This object specifies the instantaneous CPU utilization.
For five-minute-average CPU load:
ASN Name: apChassisMgrExtSubModuleCPUAverage
Object Identifier: 1.3.6.1.4.1.2467.1.34.17.1.14
Index Value: .
Description: This object specifies the average CPU utilization
This OID should be monitored periodically.
For Example:
To monitor the Instantaneous CPU load on SCM 7/1
snmpget ?c .1.3.6.1.4.1.2467.1.34.17.1.13.7.1
To monitor the 5-minute-average CPU load on SCM 7/1
snmpget ?c .1.3.6.1.4.1.2467.1.34.17.1.14.7.1
