Power Supply Unit (PSU1) reports AC lost
johng231
Level 3
Level 3
Hello
The CM is reporting this alarm for 2 674s in the same remote location. We confirmed with the local admin that the power supplies are connected and green light is on.
If you do a "show hardware", the following outputs show the power supplies are connected and powered on.
Primary Power Supply Unit (Installed; Powered)
Redundant Power Supply Unit (Installed; Powered)
How can I can clear the bottom alarm from showing up on the CM?
show alarms  det
Critical Alarms:
None
Major Alarms:
        Alarm ID                 Module/Submodule               Instance
   1 psu_ac_status             sysmon/psu1_vinok            no power
     Aug 21 13:11:55.920 UTC, Equipment Alarm, #000002, 1000:445040
John
Nicolas Fournier
Hi John,
Which version are you running on those devices?
If you are running a version preceding 4.4.5, you are most then likely running into this bug:
CSCtq33146 PSU "No Power" Alarm Raised After AC Power Cycle
More info:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtq33146
If so, I would try the second workaround that you have in the case notes.
Nicolas
Nicolas Fournier
Hi John,
More info:
Nicolas
Thanks... i'm running version 4.4.1
