Product spec reqd
surajgovindan1
Community Member
Dear All,
As a part of our software project, there are servers and Cisco swicthes in our DC, as we are going to upgrade and install new software's vendor came up with the below product.
We do not want to go with this product since we have a complete Cisco environment. What is the alternate product i can procure for this purpose?
will rate all the suggestions.
Radware 4408
Alteon 4408
Platform Highlights
  • High performance application delivery appliance
  • On-demand throughput scalability
  • On-demand service scalability
  • 6 Gigabit ethernet ports (copper) + 2 Gigabit fiber ports (SFP-GBIC Mini)
  • RJ45 serial connection
  • USB interface for software installation and recovery
  • Suitable for small, medium and large datacenter
  • Provides 500Mbps throughput scalable OnDemand up to 4Gbps
  • Provides SSL acceleration, compression, and caching
Bhavin Yadav
Hi SUraj,
If you are looking for WAAS specsheet, you can find it here:
http://www.cisco.com/en/US/partner/prod/collateral/contnetw/ps5680/ps6474/product_data_sheet0900aecd80329e39.html
Regards.
