Real Servers Outside ACE Equipment
fabricio.monte
Hi All,
Usually, I configure real server and their default gateway is inside a vlan in the own ACE module.
I configure the real servers, serverfarms and the probes and works fine.
Now I have to configure a load balance where the real servers are outside the ACE and in another equipment in the network.
I would like to know if is it possible and if is the same way if the real server  IP address were in a vlan in the ACE module.
Fabricio
Surya ARBY
Level 4
Level 4
no changes to the config, except that you will have to enable source NAT on your virtual server and use a NAT pool on the interface vlan facing the next hop of the route to reach the ressources
