REDUNDANT ACE 20 WITH SSL CERTIFICATE
RICARDO SANCHEZ
I have an ACE 20 redundant infrastructure (Active-Standby),and  it´s needed to implement a secure aplication with SSL certificate.
The question I have is, for this solution is neccesary to generate a digital certificate and key  for each ACE module? and, It´s is possible to use the same certificate and key in both ACE modules?
Thanks for your help.
Jorge Bejarano
Level 4
Level 4
Ricardo,
You can just the same certificates for both devices.
Jorge
