Regarding compression in ACE
lingaraj19
Community Member
Hi All,
I need to configure the Compression policy in ACE.
Pls can any ne explain me how to do the compression policy and troublshooting the same.
Thanks in advance.
Lingaraj
Kanwaljeet Singh
Hi Lingaraj,
You can configure compression by entering the compress command under a Layer 7 load-balancing policy. For example:
class-map type http loadbalance match-any L7default-compression- exclusion-mime-type_CLASS
description Classmap for default SLB compression exclusion mime-types.
2 match http url .*gif
3 match http url .*css
4 match http url .*js
policy-map type loadbalance first-match L7_COMP_SLB_POLICY
class L7default-compression-exclusion-mime-type_CLASS
   serverfarm SFARM1
class class-default
   serverfarm SFARM1
   compress default-method deflate
You can create the http parameter map and apply that pmap to a policy map.
parameter-map type http  compression
    compress minimum-size xxx
Kanwal
