Restoring Configuration of an SSL Module
v.kreisel
I would like to write a document
about config restore of an C6K SSL module. Restoring the saved
running-config is not enough.
Key pairs have to be imported manually. (crypto key import ...).
SSL certificates using those keys are included in the running config but "ssl-proxy- services" using those keys/ceritificates are not working after restore of saved
running-config.
Are there any experiences regarding this issue in the field ?
smahbub
Level 6
Level 6
Although there is no specific documented process for correctly backing up certificates and config and restoring, saving your SSL config is documented at the following link:
http://www.cisco.com/en/US/products/hw/switches/ps708/products_module_configuration_guide_chapter09186a00801f33c6.html#wp1164534
To backup, just change the destination to a non-local filesystem. Such as:
copy system:running-config ftp:sslmconfig
Since private keys aren't copied when this is done, it's suggested to back up key pairs and the associated certificate chain by exporting each trustpoint to a PKCS12 file. This is detailed here:
http://www.cisco.com/en/US/products/hw/switches/ps708/products_module_configuration_guide_chapter09186a00801f33c6.html#wp1091575
Hope this helps.
