"show tech" on SSL module and 6500
mcgbic
We were running some tests to our https portal using a java script. We were running into some errors. After the errors, we did a "show tech" on both the 6500 switch and the ssl-module.
We ran the same test script again, and the errors went away and was getting good results to our tests. I was wondering, did the "show tech" clear up anything in the switch and ssl-module? Is it possible that a sh tech can clear memory and other garbage? Please help. thanks
Jun
wong34539
Level 6
Level 6
The "Show Tech" command cannot clear the errors on a device. This command is mainly used to get as much information as possible from the device like the running configuration, memory usage, cpu usage etc. This is basically a troubleshooting command and hence cannot clear any errors.
