Reuse of context in ACE module
pd.politiet.no
Hi all, just have a question about som reuse of resources in a ACE module context.  I don't want to make a new context, and can reuse most of the existing configuration in one of my context.  The config is not complex and difficult, but I'm not sure if I can do this.
The primary goal is to loadbalance 2 webservers with a new vip, new serverfarm, stickygroup, policy-map and different nat-pool.
Since I haven't decided the ip addresses to be used, they are just xx in the config below.
The changes I want to implement are in bold.  Will this work for me?
probe http WEBGUI_D2
description Probe for http mot webgui
interval 10
passdetect interval 10
passdetect count 1
request method get url /D2/auth/login.aspx
expect status 200 302
header User-Agent header-value "IDENTITY"
rserver host cwi003
description content server logon
ip address 10.163.22.27
inservice
rserver host cwi004
ip address 10.163.22.28
inservice
rserver host cwi503
description content server logon 2
ip address 10.163.22.23
inservice
rserver host cwi504
ip address 10.163.22.24
inservice
serverfarm host SF_LOGON_D2
probe WEBGUI_D2
rserver cwi003 80
   inservice
rserver cwi004 80
   inservice
serverfarm host SF_LOGON2_D2
probe WEBGUI_D2
rserver cwi503 80
   inservice
rserver cwi504 80
   inservice
sticky ip-netmask 255.255.255.255 address source STICKYGROUP1
timeout 20
replicate sticky
serverfarm SF_LOGON_D2
serverfarm SF_LOGON2_D2
class-map match-all VS_LOGON_D2
3 match virtual-address 10.163.22.13 any
class-map match-all VS_LOGON2_D2
3 match virtual-address 10.163.22.xx any
policy-map type loadbalance first-match PM_ONE_ARM_LB
class class-default
   sticky-serverfarm STICKYGROUP1
policy-map multi-match PM_ONE_ARM_MULTI_MATCH
class VS_LOGON_D2
   loadbalance vip inservice
   loadbalance policy PM_ONE_ARM_LB
   nat dynamic 5 vlan 1240
class VS_LOGON2_D2
   nat dynamic 6 vlan 1240
interface vlan 1240
description Client_server
ip address 10.163.22.11 255.255.255.0
peer ip address 10.163.22.12 255.255.255.0
access-group input INBOUND
nat-pool 5 10.163.22.14 10.163.22.17 netmask 255.255.255.192 pat
nat-pool 6 10.163.22.xx 10.163.22.xx netmask 255.255.255.192 pat
service-policy input PM_ONE_ARM_MULTI_MATCH
no shutdown
ip route 0.0.0.0 0.0.0.0 10.163.22.1
BR
Geir
Daniel Arrondo Ostiz
Hi Geir,
There is no problem in having multiple VIPs in one single context.
The configuration for it would more or less be the one you sent, except for one point. In a sticky group, you can only use one single serverfarm, so, you will need to create a second sticky group for the new VIP.  This also implies that you will also need a second load-balance policy associated to the new sticky-serverfarm.
Daniel
Thanks for your reply.
Hope I understand you correct.  This sould be the config I need to paste into the existing context.
rserver host cwi503
  inservice
rserver host cwi504
  inservice
  probe WEBGUI_D2
  rserver cwi503 80
    inservice
  rserver cwi504 80
    inservice
sticky ip-netmask 255.255.255.255 address source STICKYGROUP2
   timeout 20
   replicate sticky
policy-map type loadbalance first-match PM_ONE_ARM_LB2
  class class-default
    sticky-serverfarm STICKYGROUP2
  class VS_LOGON2_D2
    loadbalance policy PM_ONE_ARM_LB2
interface vlan 1240
Br
Geir
Hi Geir,
Yes, this configuration should be fine.
Daniel
Thanks!  It works!
Br
Geir
