Router order of operation when WCCP, IOS firewall, and routing coexist?
gwhuang5398
Level 2
Level 2
On an WAN router where WCCP redirection, ip inspection, routing, QoS, IPSec, and NAT are configured, what's the order of router operation on the LAN and WAN side? I have seen a flow chart a couple of years back. So I'm hoping to see an updated one.
Thanks a lot
Well, I am not sure how old this is but we still use this as a good reference because any change in this priority order can cause lot of issues on the other side.
Regards.
PS: Please mark this as Answered, if this addresses your issue.
Bhavin Yadav
May be this is the one you are looking for.
Hope thsi helps.
Regards.
PS: Please mark this as Answered, if it answers your question.
Thanks for the info. I have seen a similar table couple of year back. Is this pretty up to date?
Regards.
Hi, I missing ingress marking , netflow and other operations in the list ?
Thx
Hubert
