SIP load balancing issue with ACE 4710
raj79_patel
SIP Load balancing Issue with ACE 4710
I have a Cisco ace 4710 with vesion Version A4(2.2). i configued simple SIP load balancing first without stickiness. without stikeiness we are having a problem because bye packet at the was not going to the same server all the time that left our port in used even though user hang up the phone. its happen randmly. i have a total 20 licenced ports and its fill out very quickly. so i dicided to use the stickiness with call-ID but still same issue. below is the config
rserver host CIN-VOX-31
  ip address 172.20.130.31
  inservice
rserver host CIN-VOX-32
  ip address 172.20.130.32
  inservice
serverfarm host CIN-VOX
  probe SIP-5060
  rserver CIN-VOX-31
    inservice
  rserver CIN-VOX-32
    inservice
sticky sip-header Call-ID VOX_SIP_GROUP
  timeout 1
  timeout activeconns
  replicate sticky
  serverfarm CIN-VOX
class-map match-all CIN_VOX_L4_CLASS
  2 match virtual-address 172.22.12.30 any
class-map match-all CIN_VOX_SIP_L4_CLASS
  2 match virtual-address 172.22.12.30 udp eq sip
policy-map type loadbalance sip first-match CIN_VOX_LB_SIP_POLICY
  class class-default
    sticky-serverfarm VOX_SIP_GROUP
policy-map multi-match GLOBAL_DMZ_POLICY
   class CIN_VOX_SIP_L4_CLASS
    loadbalance vip inservice
    loadbalance policy CIN_VOX_LB_SIP_POLICY
    loadbalance vip icmp-reply
  class CIN_VOX_L4_CLASS
interface vlan 20
  description VIP_DMZ_VLAN
  ip address 172.22.12.4 255.255.255.192
  alias 172.22.12.3 255.255.255.192
  peer ip address 172.22.12.5 255.255.255.192
  access-group input PERMIT-ANY-LB
  service-policy input GLOBAL_DMZ_POLICY
could you please help me on this...
thanks
Rakesh Patel
6 Replies 6
ajay chauhan
Level 7
Level 7
Can you post class-map for -CIN_VOX_LB_SIP_POLICY
Ajay
I mean there should be one more statement-
class-map type sip loadbalance match-any CIN_VOX_LB_SIP_POLICY
match sip header Call_ID header-value sip:
and that will be called under-
is that missing in your config ?
ya.. dont have this in my config. i thought this is just if you wthanted to do layer 7 load balancing. i have a without match criteria. well i can try to add this and see how that works.. i will let you know...
thanks.
Rakesh
what will be my header-value?
i tried to add Layer 7 Class map and now i am not getting any dial tone.
