05-06-2003 02:30 PM
I've been looking over the CCO docs, but can't find one that has sample configs for using a 3661 router containing content engine module, smartfilter, & ACNS. Topology is basically the following...
(PC's)----(LAN Switch)-----(3661 w/content engine module)----(PIX)---(internet)
I don't want to creat a new IP subnet for the 3 interfaces within the content engine module/router. I want to use the IP's from the current LAN IP Block.
Any advice appreciated.
05-12-2003 01:54 PM
Check this URL for details on Content filtering with PIX and CE with Smart filter. http://www.securecomputing.com/index.cfm?sKey=1152
05-13-2003 12:44 AM
thanks...already read through that one along with others at that site
05-27-2003 10:23 PM
Also interested to know more about these NM's in 3600s. I'm completey green on Cisco CE technology/software but have a basic grasp on wccp concept. I guess these NM-CEs run an OS (BSD?); what is the maintenance overhead, easy to configure? etc. etc.
What would be nice would be for someone who's done this before to kindly do a quick pros & cons table.
TIA!
05-29-2003 01:50 PM
I thought this might help.
Easy NM-CE Configuration Guide!
Router IOS:c3725-ik9o3s-mz.122-15.T2
Content Engine Software: ACNS 5.0.3.5
Configure basic router configuration as normal.
Set the IP addresses for the Service Module (Content-Engine) using these commands:
interface Content-Engine2/0
ip address 10.1.1.1 255.255.255.0
ip nat inside
service-module external ip address 10.0.0.1 255.255.255.0
service-module ip address 10.1.1.2 255.255.255.0
service-module ip default-gateway 10.1.1.1
Complete Config Example (DHCP and NAT for Lab):
urrent configuration : 2440 bytes
version 12.2
hostname lab3745_NM-CE
logging queue-limit 100
enable password cisco
ip subnet-zero
ip wccp web-cache
ip dhcp pool NM-ESW-16-POOL
network 10.1.2.0 255.255.255.0
domain-name cisco.com
default-router 10.1.2.1
dns-server 171.68.226.120 171.70.168.183
lease 7
ip audit notify log
ip audit po max-events 100
no voice hpi capture buffer
no voice hpi capture destination
mta receive maximum-recipients 0
interface FastEthernet0/0
ip address 172.16.12.108 255.255.255.0
ip wccp web-cache redirect out
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet1/0
no ip address
interface FastEthernet1/1
no ip address
interface FastEthernet1/2
no ip address
interface FastEthernet1/3
no ip address
interface FastEthernet1/4
no ip address
interface FastEthernet1/5
no ip address
interface FastEthernet1/6
no ip address
interface FastEthernet1/7
no ip address
interface FastEthernet1/8
no ip address
interface FastEthernet1/9
no ip address
interface FastEthernet1/10
no ip address
interface FastEthernet1/11
no ip address
interface FastEthernet1/12
no ip address
interface FastEthernet1/13
no ip address
interface FastEthernet1/14
no ip address
interface FastEthernet1/15
no ip address
ip nat inside
interface Vlan1
ip address 10.1.2.1 255.255.255.0
ip nat inside
ip local pool NM-ESW-16-POOL 10.1.2.2 10.1.2.254
ip nat pool TEST-NAT-POOL 172.16.12.108 172.16.12.108 prefix-length 24
ip nat inside source list 7 pool TEST-NAT-POOL overload
ip http server
no ip http secure-server
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.12.254
access-list 7 permit 10.1.2.0 0.0.0.255
access-list 7 permit 10.1.1.0 0.0.0.255
access-list 7 permit 10.0.0.0 0.0.0.255
call rsvp-sync
mgcp profile default
dial-peer cor custom
line con 0
speed 115200
line 65
flush-at-activation
no activation-character
no exec
transport input all
line aux 0
line vty 0 4
password cisco
login
end
reset service-module 2 to reboot the Content-Engine:
service-module content-Engine 2/0 reload
Within 30 Seconds Session from the Router to the Service Module:
service-module content-engine session
Enter Basic Configuration for Network Module:
Password, etc
Configure The service Modeule using the command line interface:
hostname NM-CE-BP
ip domain-name CISCO.COM
interface FastEthernet 0/0
exit
interface FastEthernet 0/1
exit
primary-interface FastEthernet 0/1
ip name-server 172.72.1.1
wccp router-list 1 172.16.12.108
wccp web-cache router-list-num 1
wccp version 2
username xxx password xxxx
username xxxx privilege 15
authentication login local enable primary
authentication configuration local enable primary
NM-CE-BP#exit
You can use the command line interface to show statics from the Content Engine by using the show statistics screen command or use your web browers for a more graphical report.
05-29-2003 03:04 PM
thanks. the configs help a lot
